2/23/2023 11:09 AM | |
Joined: 4/26/2012 Last visit: 12/11/2023 Posts: 1448 Rating:
Hello, to help you get ideas, take a look at the attachment, in the Unified F1 help, there is a syntax example, try to make a simple one to test first. For forEach take a look at this LINK. use RTILtraceViewer for debugging. I hope it helps you. good luck |
"Always make a backup before and check the best time before testing." |
2/23/2023 5:16 PM | |
Joined: 11/28/2022 Last visit: 12/1/2023 Posts: 18 Rating:
Hello, Thanks for the tip, though I'm still struggling to find a way to address the array declared in HMI tags. I haven't got a problem with the forEach method. Regards
2/23/2023 5:26 PM | |
Hello, this video LINK has two parts. Can you use RTILtraceViewer? Is it possible for you to put an attached image of the array declaration?
Last edited by: rdoliveira at: 02/23/2023 17:29:37Last edited by: Jen_Moderator at: 02/24/2023 06:42:27Video embedded. "Always make a backup before and check the best time before testing." |
2/24/2023 12:50 PM | |
Hi, glad you got it. good job.
