4/2/2008 9:02 AM | |
Joined: 9/28/2005 Last visit: 12/10/2024 Posts: 2957 Rating: (243) |
Hi, Then you'll have some problems. I don't know exatly if these two protocols are open. If so, you canget detailed information on them and try to write driver by yourself and use one of siemens serial communications processors. Other way is to find protocol gateway from M-Bus or LON to one of siemens supporting protocols: MPI, Profibus or Modbus. Try to look here: http://www.intellicom.se/gateways.shtmlor here http://www.leitsystem.ch/Eth/doke/LONMultiprotokoll.pdf Good luck. Regards, |
Best regards, |
4/2/2008 10:02 AM | |
Posts: 5822 Rating: (412)
Hello, do you know if LON is the same as LonWorks? Best regards J_Bell |
4/7/2008 4:01 PM | |
Deat Ton, |
10/23/2009 8:51 AM | |
Joined: 4/20/2007 Last visit: 12/13/2024 Posts: 728 Rating: (43) |
Hi again! I was just wondering if Siemens has found a solution for communication between M-Bus and S7-300 PLC's. Ton |
