5/20/2009 8:41 AM | |
Joined: 3/18/2009 Last visit: 12/6/2024 Posts: 306 Rating: (94) |
Hello monchotbs. We have an example provided in the online help of WinCC for a similar use. I have attached the relevant part for you to go through. It contains a sample VBA script. Since the example uses the Siemens WinCC OPC server and Siemens OPC DAAutomation 2.0 reference, you will have to make relevant changes in the script for Kepware server and the reference. Hope this helps. regards.
AttachmentOPCClientinExcel.pdf (1170 Downloads) |
5/20/2009 2:52 PM | |
Posts: 2 Rating: (0) |
Thanks so much for your quick answer Today i will try it and i tell you if it works Ragards |
