10/9/2014 5:40 PM | |
Joined: 9/3/2014 Last visit: 3/7/2024 Posts: 79 Rating: (4) |
Dear Experts, I am trying to read a CPU 6ES7314-6BG03-0AB0 program with TIA PORTAL V12, I need to make a backup, but when I read the program some blocks show an error message, those messages are: For example, the Cpu Used does not support the block DB200 and other message is, blocks loaded from a s7300 / 400 module SCL can not be processed, Would you can to help me, explain me these problems and how can I solve? Thank you so much for your collaboration, Best Regards, AttachmentError.pdf (118 Downloads) |
