12/28/2010 7:24 AM | |
Joined: 10/7/2005 Last visit: 1/30/2023 Posts: 2954 Rating:
Hello algudkar simply connect them to the MPI port of your 314 (the KTP 1000 also supports MPI), make sure to giveeach Panel and the CPU a unique MPI address, link them all up with Profibus cable and connectors and it will work. Hint: Use a "Piggyback" Profibus plug on the CPU's MPI port so you can still connect your programming laptop too it too. I hope this helps |
Cheers |
