7/24/2017 10:27 AM | |
Joined: 5/28/2008 Last visit: 2/12/2025 Posts: 4518 Rating:
Hello, In the technical specification of the panel, you can check which controllers can be connected to the KTP1200. Pleae check "process coupling" section of the following link: https://support.industry.siemens.com/cs/pd/217731?pdti=td&lc=en-US |
Ayman Elotaify |
7/24/2017 10:43 AM | |
Posts: 6 Rating:
i see that GE is not mentioned to be coupled with this hmi , but the mentioned was about direct coupling, and in my case i think i should use converter to unify the communication protocol ? |
