5/5/2017 10:47 AM | |
Joined: 8/3/2009 Last visit: 3/17/2025 Posts: 14998 Rating:
Hello Prian If its a softwarebased issue then you could try to reset the Panel to factory settings: https://support.industry.siemens.com/cs/ww/en/view/19701610 If its not better afterwards then I suppose its a Hardware issue. Bye Murof |
