12/26/2022 9:12 PM | |
Joined: 8/6/2018 Last visit: 4/22/2025 Posts: 366 Rating:
Hello, Are you using an adapter? How have you configured the PC/PG interface? Thanks you |
1/16/2023 1:08 PM | |
Hello henry213cncn I would use a CP5711. We always use this for transfering to MPI/DP to HMIs. (the PC Adapter is not released for every panel) If nothing works and you have a newer OS Version on the Panel you also can do an offline transfer with USB Stick: https://support.industry.siemens.com/cs/de/en/view/109740696 Bye Murof |
