3/6/2018 1:52 PM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello swowoarol gonig online with a panel like a PLC makes no sence. the panels have less functinoality in online diagnostic. But If you want to load your HMI Project to the Panel you have to be sure to open all needed ports in the Firewall or the router if you work with VPN. Here in the manual you cann see the used ports: https://support.industry.siemens.com/cs/ww/en/view/109742297/87204625803 Bye Murof |
