1/2/2018 1:47 PM | |
Posts: 200 Rating:
Hi Any ideas my screen is locked to the startup screen and wont connect either through TIA Thanks Andrew |
1/2/2018 2:27 PM | |
Posts: 200 Rating:
Hi Thanks for the reply. I have tried this but i cant even connect to the HMI I can connect to my PLC fine |
1/2/2018 2:54 PM | |
Posts: 200 Rating:
Where do i find pro save as i haven't had to do this before |
1/2/2018 3:08 PM | |
Joined: 4/24/2006 Last visit: 3/23/2023 Posts: 8586 Rating:
Hello, You can download here But when you have WinCC TIA Portal, it is also installed on your PC, look under Automation -> HMI Tools Best regards, Wizard |
1/2/2018 3:39 PM | |
Posts: 200 Rating:
thanks for the help i have tried the download but was denied for some reason i shall try again |
1/2/2018 3:49 PM | |
Posts: 200 Rating:
Hi I have powered down the unit again and for some reason it has sprung into life Would it be best to do a reset before using |
