12/17/2015 9:28 AM | |
Joined: 1/10/2011 Last visit: 8/23/2023 Posts: 23 Rating:
Hi, I am using KTP700 Basic PN in my project. I am facing a problem in recipe view, in the Value coloum the last digit of the value is not visible if the scrollbar is visible. What Must Be the problem can some one give me some solution. Thanks in advance, Regards, Harshal. ------------------------------------------------------------------------------------------ |
Last edited by: CS Moderator at: 12/18/2015 1:33:56 PMNew subject after splitting |
12/18/2015 5:25 AM | |
Hello, The Version is TIA Portal V13 SP1 Update4 Thanks. Harshal |
12/18/2015 6:39 AM | |
Hello Sir, Attaching herewith 2 links for photos. Photo-1 = all digit visible without scroll bar. Photo-2 = last digit not visible/ hidden because of scroll bar. I had checked in Recipe Properties but could not find any text alignment setting such as right/left/center. Can you pls suggest some solution our project is near to completion. Thanks, Harshal. |
12/18/2015 8:50 AM | |
Joined: 4/24/2006 Last visit: 9/29/2023 Posts: 8593 Rating:
Hello, Please try to use the latest update: Updates for STEP 7 V13 SP1 and WinCC V13 SP1 Best regards, Wizard |
12/18/2015 11:21 AM | |
Hello Sir, Shall Install the latest (update 6) and give the feedback. Thanks, Harshal |
12/21/2015 8:48 AM | |
Hello Harshal, My suggestion would be to start a "Support Request" ps.: Let us know the results! Best regards, Wizard |
