11/28/2017 8:55 AM | |
Posts: 1 Rating:
Hi Im working with an ktp700 f and I had to move the location of where the hmi gets docked so I un wired it from the back of the hmi to fit the cable trough the gap to relocation when I rewired it the e-stop came on but the screen was black so I switched of power to the ktp700f as a means to reset it but the condition did not change but when I left it for a while the screen saver came on do you know maby why I cant access the interface and do you please have a solution for me thank you ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/29/2017 10:15:45 AMNew subject after splitting |
11/30/2017 11:03 AM | |
Hey Vraze, do you know the application example "Using the Mobile Panels 2nd generation in Fail-Safe Applications"? https://support.industry.siemens.com/cs/ww/en/view/103497649 There you can find a Gettings Started and a application describtion. Therefor you can prove if you have done the right Settings. With best regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
