3/25/2010 5:26 PM | |
Posts: 3 Rating: (0) |
Subba, The insulation monitor is used if the drive is operated on an ungrounded supply. The two threshold values can be set (for alarm and fault). |
3/31/2010 8:01 PM | |
Subba, See attached data sheet for the Bender Unit. You can download this at Bender website. The unit functions as described. AttachmentIRDH275BM-7_DB_en[1].pdf (399 Downloads) |
