1/10/2006 11:20 AM | |
Posts: 2 Rating:
Hi, I need to find some possibility how torun vb script from C-action please give me an example if existe some solution. Thank you Steev |
1/10/2006 12:51 PM | |
Posts: 3149 Rating:
Hi Steev, acc. to my informations it´s not possible to mix C- and VB calls: http://support.automation.siemens.com/WW/view/en/18520917 Chapter 6.1 in the manual: http://support.automation.siemens.com/WW/view/en/15342782 Regards, Nemo |
1/10/2006 3:33 PM | |
Joined: 9/8/2005 Last visit: 8/3/2023 Posts: 177 Rating:
Hi, not realy what your are need (exactly the opposite), but perhaps useful: The WinCC Competence Center Mannheim does provides the tool "WinCC Script Connector". The tool allows to launch C actions from VBS. More informatiosn about the tool http://siemens.com\process-management-> Support -> WinCC Tools Michel |
1/10/2006 5:18 PM | |
Posts: 1084 Rating:
You could set a bit in a tag on the system by the first script. Then use this tag to trigger the other script. Hopes it's usefull. with regards |
