3/23/2012 9:45 AM | |
Joined: 4/29/2010 Last visit: 8/12/2024 Posts: 1557 Rating: (161)
Hello, check our the demo project for WinCC (TIA Portal) there is a KTP400 Basic project with mono display. You can use the graphics for your project for example. I understand whats your problem, but i you want a professional look it would be better to use a color display. Demo projects for HMI Panels at WinCC (TIA Portal) for Basic Panels, Comfort Panels and WinCC Runtime Advanced (TIA Portal) best regards |
3/26/2012 1:26 PM | |
Posts: 3037 Rating: (192)
Hello, you can see the following link all objects that you can use with your panel. What are the functional differences between the different SIMATIC panels? You can not create your own button. You can use the button under WinCC V11 with events (click, press, release, activate, deactivate, change). You can animate your object under animations. Here you can use diagonal movement for example. You can not use a bit for navigate this movement. You can use a datatype int. Tweety |
3/26/2012 8:50 PM | |
Posts: 36 Rating: (2) |
Hello, Ok,so there are no backports to make ithappen ? Thx for the response |
3/27/2012 11:07 AM | |
Hello, I can not understand what you mean. Tweety |
