7/18/2008 9:57 PM | |
Posts: 3149 Rating:
Hi perhaps you should use this addon http://support.automation.siemens.com/WW/view/en/10343086 nemo |
7/19/2008 10:10 AM | |
Posts: 88 Rating:
thank you your answer.. I read this docu but can not able to do this :(((( first of all I can see servers and plc on the LBM its ok but I can not see the situtaion of the client from server. I configure it according to attached zip file. but could not be able to do this. :((( When I push the TEST Server button on the opc server connection properties, it says "this server not active can not reached by the computer network or does not support the opc interface" I open the component services on the client PC and I have given the permissions but same result. I dont know how to configure it :((( AttachmentConfiguring_Lifebeat_Monitoring_for_an_OS_Client.zip (35 Downloads) |
