11/21/2011 10:55 AM | |
Joined: 8/31/2010 Last visit: 1/31/2023 Posts: 1498 Rating:
Hello brinbr, Check if this works for your case How can you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed? |
Like it? Rate it! |
11/21/2011 1:07 PM | |
Posts: 8 Rating:
Yes, I moved the license from a USB stick to Hard drive. I tried to delete the trial license, but this not solved the problem Regards |
