6/17/2019 5:03 PM | |
Joined: 5/25/2011 Last visit: 12/18/2023 Posts: 4 Rating:
Hi Guys I am trying to connect s7-1200(CPU 1214C FW4.2) to laptop(TIA V15.1) using OPC server(SW 15..). I follow the instructions in last part of (page 35 onward) of https://cache.industry.siemens.com/dl/files/679/39960679/att_117996/v3/39960679_s7-1200_opc_simatic-net_tia-portal_e.pdf when I get to Establish connection to OPC server(page 68), and click on UA server. It displays" Local UA server Could not open UA TCP request channel" in red colour. Any ideas? Thanks HK ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/18/2019 11:15:41New subject after splitting |
6/17/2019 5:34 PM | |
Joined: 8/15/2011 Last visit: 9/9/2024 Posts: 145 Rating:
Hello, maybe helps... OPC Scout: UA server Find servers error: Could not open UA TCP request channel. |
6/28/2019 3:09 PM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello Arcarc so do you want to use OPC UA or OPC DA (DCOM Based)?? Because in your posts there are mentioned both https://support.industry.siemens.com/cs/ww/en/view/67295801 Bye Murof |
