3/12/2024 8:58 AM | |
Joined: 8/3/2009 Last visit: 1/23/2025 Posts: 14651 Rating: (1823)
Hello Shakeyjim87 generally it should work... which Upd do you have installed in TIA V17? and which Panel image do you use? You could try to use this: https://support.industry.siemens.com/cs/de/en/view/109778709 Check also if it works in Simulation on PC with this project Bye Murof |
