12/28/2014 2:19 PM | |
Joined: 1/28/2009 Last visit: 12/28/2022 Posts: 6785 Rating:
Hello Martins_Eng, What is your target CPU in TIA portal?S7-1200 doesn't support STL and for S7-300/400 try to export the function as an external source and import it in TIA Portal. The nextway, would be migrating the whole project from STEP 7 to TIA Portal.
And finally, if you have the hardcopy of thefunction, you should implement the function again.Create the input/outputs of function andassign names for temp variables in the function. Try one of the suggested ways and update here, Best regards, Hamid Hosseini |
