12/23/2020 10:36 AM | |
Joined: 2/6/2015 Last visit: 4/4/2025 Posts: 80 Rating:
Hi Agilesh, Maybe this example can help you: How do you access an SQL database in WinCC Runtime Advanced usin a script? https://support.industry.siemens.com/cs/ww/en/view/61883659 Other option will be archive tags and messages in an SQL: https://support.industry.siemens.com/cs/ww/en/view/61886098 Best Regards, CGA81 |
