2/8/2024 2:40 PM | |
Joined: 8/12/2021 Last visit: 4/11/2025 Posts: 351 Rating:
Hi! In theory, you should be able to through a script and the logon and logoff functions. The problem is that you would have to create logic that would allow you to check the time to allow access to a user or not. I have searched a little but I have not seen that there is an example of this programming in SIOS
