1/8/2011 1:27 PM | |
Posts: 10 Rating: (0) |
Hello, Does LOGO! TD backlight start to lit when buttons of the TD panel are pressed and stays lit for a while? Thanks in advance! |
1/8/2011 10:14 PM | |
Posts: 2930 Rating: (432)
Hi, Yes, this is the default setting. You can also control the backlight via a merker, or you can switch it on constantly in the TD settings. Hope this helps |
