4/24/2012 3:33 PM | |
Posts: 495 Rating: (58) |
Can you upload your program please? It will be helpful for checking your issue. |
4/24/2012 3:44 PM | |
Posts: 24 Rating: (0) |
Here is my program AttachmentBanc_pression.zip (313 Downloads) |
4/24/2012 3:50 PM | |
But I think, it's not a software problem but a hardware problem |
4/24/2012 6:02 PM | |
Joined: 1/5/2007 Last visit: 4/7/2023 Posts: 1690 Rating: (581)
Hi,, |
==> Meine TAG-Listen: "deut." |
4/24/2012 10:12 PM | |
Hello again, a) the ON-delay cant working with cursor keys - not on bacic module and not at the TD - because by pressing [ESC] + cursor key LOGO! get only one pulse for one LOGO! cycle time, sorry Asolution ist to use extenal keys or the F-keys b) Get the cursor key if you control the LOGO! over the TD (i means change the lOGO!-menues? c) Somtimes and at some LOGO!s the rection if pressing [ESC] + cursor keyis failed d) At the german forum i have no found that error description from you! Best regards Betel |
4/25/2012 7:33 AM | |
Logo: 0ba7 logo td: 6ed1 055-4mh00-0ba0 |
4/25/2012 5:58 PM | |
Hi, the underline indicates that you are aktivated the edit mode of the messagebox (with hold [ESC] for some seconds - that i have some times too). If you have this press [ESC] again and you are back in normal display mode Please look at the handbook for more infos. If you are in edit mode, you can use the cursor keys <, > to change the variable (if you have mor than one insid this textbox); press OK to EDIT the Value then with ub and down.... Best regards Betel |
4/27/2012 8:41 AM | |
I have not find this in the handbook, what page is it ? Thanks, |
