4/29/2013 8:50 PM | |
Joined: 12/27/2006 Last visit: 7/7/2024 Posts: 1197 Rating:
Using blocks :"Analog Ramp" |
4/30/2013 8:21 AM | |
Posts: 5 Rating:
I've tried that, I can ramp up and down but only at the same rate. How can I get different ramps up and down. |
4/30/2013 10:43 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Hello, Then you have to be a little creative, use a Asynchronous pulse generator together with a Up/down Counter to generate the Sawtooth or build a few blocks around the ramp. I have attached an example Regards, Marcjan Attachmentsaw_forum.zip (293 Downloads) |
Last edited by: Marcjan at: 4/30/2013 10:58 AMLast edited by: Marcjan at: 4/30/2013 10:51 AMProblem solved? |
4/30/2013 8:33 PM | |
Use 2 Analog Ramp block with a different speed. Look in the attachment Attachmentzaagtand.zip (243 Downloads) |
5/2/2013 11:37 AM | |
Posts: 5 Rating:
Thank you both for you help, there's obviously more than one way to arrive at the solution. I've used a combination of suggestions from the forum to arrive at the attached solution.
AttachmentPressure Control.zip (290 Downloads) |
