5/31/2011 9:20 AM | |
Joined: 4/19/2008 Last visit: 1/17/2023 Posts: 1525 Rating:
Hi Shivam, Can you tell me Which Software you are using for the Communication with the S5? also Which Cable is using for the Communication ? Because If you have the Step 5 & TTY cable then it is not required any Driver for it. Here is the Link for the S5 Communication Cable |
Ammy |
5/31/2011 12:29 PM | |
Posts: 11 Rating:
Dear Ammy, Thanks a lot for your reply. Actually we have been able to communicate to the PLC (6ES5 928 3UB21) using step5 and a tty converter. Thanking you once again. new question is splitted to we want to do data logging from the PLC through two ports. |
5/31/2011 1:01 PM | |
Hi Shivam, While Looking for Prodave Win I found One Link , But it is very old & I don't know it will help you or not, Basically S5 PG port is work on the AS511 Protocol & there is no Information about it...... Search For Prodave Win in Google if you Find more. Best of Luck |
Ammy |
5/31/2011 2:02 PM | |
Posts: 11 Rating:
Thanks Ammy ...............
