7/17/2006 12:02 PM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating: (151)
I don't know if you can configure Loop In Alarm using the Basic Process Control Editors. However you can do it manually from the Alarm Logging Editor (this is the WinCC way [:D] ). Simply right-click on the message, select Properties and go to the Tag/LoopInAlarm tab to configure which picture you want to open. This FAQ will be helpful if you do this manually : http://support.automation.siemens.com/WW/view/en/70700 Does anyone know of any other way to do this in WinCC ?? |
7/17/2006 1:34 PM | |
Posts: 22 Rating: (0) |
Hi Salma, AttachmentBook2.zip (410 Downloads) |
Last edited by: thuan_td95 at: 7/17/2006 2:27 PMLast edited by: thuan_td95 at: 7/17/2006 1:36 PM |
