9/13/2010 5:00 AM | |
Joined: 7/28/2010 Last visit: 7/16/2023 Posts: 184 Rating:
Jim, As Ton has mentioned, you need external 24VDC. Referring to your drawing, you have an external 24VDC there. You better use the 24VDC which is feeding the Analog Card. Take a look at Figure 4-13 in the attached file. Regards, Behnam www.sigmaprocess.ca/blog AttachmentConnecting 2-Wire Transmitters.pdf (191 Downloads) |
