1/31/2012 2:06 AM | |
Joined: 9/27/2006 Last visit: 12/7/2024 Posts: 12301 Rating: (2692) |
Hello Jeff; In the following manual Ihave found these references to P42 (P indicating a Permanent error that can cause damage to the unit: 42 P42 - Current output Current loop is disconnected or the loop resistance is too big |
1/31/2012 9:33 PM | |
Posts: 4 Rating: (0) |
Thanks for your help. So I'm going to assume that the output current is what read from the pulses the unit makes while fluid is flowing ? |
