11/5/2010 2:04 PM | |
Joined: 1/28/2009 Last visit: 6/8/2023 Posts: 6805 Rating:
Hello 7sin (tradition in persian history) check this link for useful information, it is like SLD 4 L 298 SLD 3 // SKIP BIT NUMBER SLD 1 //MULTIPLY BY 2 T #Point //double word L #Point LAR1 L DBW [AR1,P#0.0] T DBW [AR1,P#4.0] best regards |
Last edited by: hdhosseini at: 11/5/2010 2:37 PMLast edited by: hdhosseini at: 11/5/2010 2:19 PMLast edited by: hdhosseini at: 11/5/2010 2:16 PM |
11/5/2010 2:31 PM | |
Posts: 7 Rating:
best regards Hellohdhosseini, thank you for your response. could you explain me the rest of the code: OPN DB150 L 298 SLD 3 // SKIP BIT NUMBER// SLD 1 //MULTIPLY BY 2 // *I T #Point // when you do this you get an integer number // L #Point LAR1 // how does this work, here you load the integer nummer into AR1// L DBW [AR1,P#0.0] // and here you load p#0.0 of AR1 into accu1. what is p#0.0 pointing to? what position of db150?// T DBW [AR1,P#4.0] |
11/5/2010 3:44 PM | |
Dear 7sin (traditional symbol of persia for Noroz) check the attachment for the online test of codes. regards Attachmentonline test.zip (126 Downloads) |
