6/9/2023 11:00 AM | |
Joined: 8/3/2009 Last visit: 4/29/2025 Posts: 15373 Rating:
Hello Jerimae you have to use each other as Multicast proxy and use the TTL Livetime also a defined enchrypted port in simatic Shell would be good for communication. Here in the WinCC Manual are a few information: https://support.industry.siemens.com/cs/ww/en/view/109792585/125855967499 (technically its almost the same in WinCC Prof) Bye Murof |
