8/24/2022 3:13 PM | |
Joined: 11/2/2016 Last visit: 11/18/2024 Posts: 1 Rating: (0) |
Hello Have you find solution of your problem? I have the same problem, when i manually move the shaft and after this I set enable, motor goes back to last positioned position. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/25/2022 07:39:19New subject after splitting. Last edited by: Jen_Moderator at: 08/25/2022 07:39:36 |
8/25/2022 8:01 AM | |
Joined: 1/21/2013 Last visit: 12/3/2024 Posts: 3330 Rating: (521) |
Hi r1af2l, this behavior is due to the fact that the previous setpoint is still active. When using telegrams 110 or 111, you can activate the tracking mode (POS_STW.0 or POS_STW2.0). In this mode, the setpoint follows the actual position. Kind regards |
