2/4/2021 6:29 AM | |
Joined: 5/11/2017 Last visit: 10/27/2023 Posts: 59 Rating:
Mapping is definitely not necessary with the dynamic optimization in TIA you can directly make any changes in IO or even in the DB Variables and the same will be applied throughout the project Data blocks (DB) are used for storing variables of different data types, For single/multi instance memory of the Standard block call. For programming guidance there are many manuals, Documents, Example Projects and videos are available in the SIOS portal you can access from below link https://support.industry.siemens.com/cs/ng/en/view/109751825 |
Last edited by: SahilU at: 02/04/2021 06:31:37Last edited by: Jen_Moderator at: 02/04/2021 10:32:47Optimized links. |
2/4/2021 7:47 AM | |
Posts: 3 Rating:
Thank you for the good explanation Sahilu, highly appreciated! |
2/4/2021 11:10 AM | |
Posts: 3 Rating:
Thank you for the extensive reply Qwazze |
