1/7/2013 11:48 AM | |
Posts: 3609 Rating:
Import of a Technical Question of the User murat_solak
1/7/2013 3:25 PM | |
Joined: 9/23/2005 Last visit: 12/5/2023 Posts: 4281 Rating:
Hi, As I suppouse, you will work with servo positioning. I found two examples in internet, depending of the hardware (or communication) that you have: SINAMICS V: Positioning of a V60 using S7-1200 (TIA-Portal) with puls/direction interface and HMI (CE-X7) http://support.automation.siemens.com/BR/view/pt/38391227 SINAMICS S: Positioning of a S110 using S7-1200 (TIA-Portal) with USS®-Protocol (CE-X9) http://support.automation.siemens.com/BR/view/pt/40616058 If you need just control the driver without "axe" functions, there is other examples at http://support.automation.siemens.com/BR/view/pt/34677186/136000&cspltfrm |
Denilson Pegaia |
