8/30/2017 9:38 AM | |
Posts: 6 Rating:
Hi, I'm trying to connect CPU 314C-2DP and CPU 313C-2DP by Profibus DP, but unsuccessfully.I used at least two manuals to configure the connection by executing the instructions step by step, again and again and spent 2 days on it. Simatic Manager joins them in one profibus network, but does not work on emulator or on real devices. The test program was unchanged. Below I am attaching the manual that I used and ask you to help me understand what I'm doing wrong. Maybe there are configurations not mentioned in the manual?
Attachmentlab200_1334756820.pdf (63 Downloads) |
8/30/2017 10:42 AM | |
Posts: 6 Rating:
Both in RUN mode, SF lights, and the BF blinks
AttachmentProfiB_4.zip (34 Downloads) |
8/30/2017 10:59 AM | |
Posts: 6 Rating:
The cable works because I used it to transfer the program to the CPU. In any case, many thanks |
8/31/2017 2:23 PM | |
Posts: 6 Rating:
Decided!!! Indeed, there were problems with the network |
