4/10/2016 11:17 AM | |
Posts: 8946 Rating:
Perhaps this link is helpful: I was searching for this some time ago, if I find the Information, I will give you additional feedback... OK, here we are: http://www.hpcfactor.com/support/cesd/h/0044.asp Because TP1200 has CE6.0 (right?), max. USB Stick is 32 GB. |
4/10/2016 5:38 PM | |
Joined: 5/28/2008 Last visit: 1/29/2025 Posts: 4518 Rating:
Hello, I think this thread may help you: https://support.industry.siemens.com/tf/ww/en/posts/94600/ I know that it's an old thread for MP277 10'' but both MP277 & TP1200 are based on the same OS (Windows CE V6.0) So, I think the same rule applies. |
4/11/2016 8:35 AM | |
Joined: 8/27/2006 Last visit: 10/22/2024 Posts: 719 Rating:
This thread is discussing the SD card capacity. My question was about the external USB stick. Thanks |
The more you know, The more you know that you don't know |
4/11/2016 8:49 AM | |
Dear Ahmed, I am not very much sure. But for Comfort Panels & 2nd Generation BasicPanel, it may be 16GB. Siemens have this USB stick released for delivery: 6ES7648-0DC60-0AA0 SIMATIC IPC USB-FLASHDRIVE 16GB SIMATIC IPC, USB-FLASHDRIVE, 16 GB, USB 3.0, INCL. SIMATIC IPC BIOS-MANAGER (INST) BOOTABLE, METAL HOUSING FOR COMFORT PANELS, BASIC PANELS 2ND GENERATION, IPC, WITH USB INTERFACE ADDITIONAL INFORMATION: SEE TECHNICAL DATA
Ayman Elotaify |
4/11/2016 9:12 AM | |
Dear Ayman, In the technical specifications of the panel it states the capacity in the attached picture. But I don't know what is the difference between "USB memory", "IPC USB" and "HMI USB" Also, the IPC USB is USB3.0, but the USB port on the panel is USB2.0, so it's also confusing. |
Last edited by: AMAZINGAHMED at: 4/11/2016 9:14:07 AMThe more you know, The more you know that you don't know |
4/11/2016 9:23 AM | |
Posts: 8946 Rating:
IPC = PC with Windows HMI = Panel with Windows CE |
4/11/2016 12:38 PM | |
But the two are mentioned in the panel's datasheet (attached) in page 9/10 as options to connect through USB port. So what's the explanation of this? Attachment6AV21240MC010AX0.pdf (243 Downloads) |
4/11/2016 12:57 PM | |
Joined: 4/24/2006 Last visit: 2/7/2025 Posts: 8839 Rating:
Hello, I have found this link: Best regards, Wizard |
