11/27/2017 8:59 AM | |
Joined: 1/4/2007 Last visit: 9/22/2023 Posts: 1059 Rating:
Hello Majok, Into the technical data sheet (see also the attached file), you can see the “Rated measuring path”. For your 6kg load cell the “Rated measuring path” is 0.24 mm. Best regards Siwarexi AttachmentWL260 SP-S SB.pdf (141 Downloads) |
