5/11/2022 4:46 PM | |
Joined: 10/11/2006 Last visit: 1/22/2025 Posts: 5985 Rating:
Hello first try to move the axis with the TO's control panel. Info about the connection via GSD: Link: How Can You Integrate a Drive into the TIA Portal via the Device Master File (GSD)? https://support.industry.siemens.com/cs/de/en/view/73257075 supplementary the docu for Motion Control https://support.industry.siemens.com/cs/ww/en/view/109781848 Monitoring: In the communication settings you can also see the status (Telegram) in the drive.
With best regards, |
5/12/2022 11:27 AM | |
Joined: 11/4/2011 Last visit: 2/18/2025 Posts: 257 Rating:
Hi, I bet you haven't checked ensured the requirements for being able to enable the TO with MC_Power have not been checked. Doing this in order to ensure that enabling the TO is possible, is absolutely mandatory. See here for closer information on what to check and how to do this: https://support.industry.siemens.com/cs/de/en/view/109750297 Regards, |
