1/23/2016 3:28 PM | |
Joined: 11/29/2011 Last visit: 2/2/2023 Posts: 1346 Rating:
Hi, Have a look at SIMATIC S7-1200 Easy Book under chapter "6.4 Easy to create data logs". I hope I could help! |
Last edited by: MicroMan at: 1/23/2016 3:29:41 PM- What you read here, please check with manuals and your requirements. |
1/23/2016 3:46 PM | |
Joined: 9/27/2006 Last visit: 2/5/2023 Posts: 11949 Rating:
Hello Rakmateusz; Analog modules (from all PLC manufacturers) use a ADC (analog-to digital converter circuit, for analog inputs) or a DAC (digital-to-analog converter circuit, for analog outputs) that converts the sensor values in Volts or mA to/from a digital (numerical) value that makes sense to the CPU's operating system. See this article from Wikipedia for basic notions on ADC: https://en.wikipedia.org/wiki/Analog-to-digital_converter See the technical data of the S7-1200 analog modules, from the same manual as suggested earlier. Hope this helps, Daniel Chartier |
