2/6/2011 11:55 AM | |
Joined: 10/7/2005 Last visit: 6/3/2023 Posts: 2966 Rating:
Hello bugsbuster check if FB "IM308C" is used in your program (default number is FB192). The(F)FC00 DP window address is dedicatedfor usage with this FB. Shouldthis FB"IM308C" NOT be used in your S5 program, it means that soemone with some good insider knowledge decided to program the data exchange between the CPU and the IM308C the "hardcoded way" (perhaps for no other reason than that they could). Just in case you don't havethis manual yet, chapter 6 of theET 200 Distributed I/O System with IM 308-C manual at least lists the available address ranges. I hope this helps at least somewhat |
Cheers |
