9/11/2023 9:27 AM | |
Joined: 2/17/2020 Last visit: 9/22/2023 Posts: 871 Rating:
Hi, If the CPU is in this state, I believe the following helps:
If this post helped you in any way, please rate it positively. |
9/11/2023 9:53 AM | |
Joined: 10/23/2015 Last visit: 9/15/2023 Posts: 149 Rating:
Hello, Thank you for your answer, I did it, reset the Memory Card But i still have the same problem Thanks |
9/11/2023 12:22 PM | |
Hi, The memory Card: 6ES7954-8LE03-0AA0 The PLC: 6ES7517-3FP00-0AB0 Thanks |
9/11/2023 12:28 PM | |
Hi The memory Card: 6ES7954-8LE03-0AA0 The PLC: 6ES7517-3FP00-0AB0 I didnt insert the card in the PC Thansk |
9/12/2023 11:57 AM | |
Did you see my answer |
