4/24/2023 9:23 AM | |
Joined: 9/12/2020 Last visit: 12/18/2024 Posts: 1 Rating:
Hi. Does anyone know which memory cards that are available for S7-1500 CPU series, and for Unified panels? Is there a difference between the memory cards used for CPU's and HMI's, or can they be used for both? |
4/24/2023 9:42 AM | |
Joined: 5/6/2022 Last visit: 4/4/2025 Posts: 581 Rating:
Hi eirik0101, Yes, they are different cards. You need a specific card for each equipment, you can't use the same ones. Below, I share with you the links where you can find the necessary cards. In the case of Unified panels you can find these cards (SD Memory Cards): "SD memory cards, 512 MB, 2 GB to 32 GB for SIMATIC HMI Panels, HMI Unified and IPC" For your S7-1500 equipment you will need to use a specific S7 Memory Card like the one I show you in the following link: "SIMATIC S7 Memory Card, 12 MB" I hope this information is useful for you. Best regards! |
To explore the new Forum, you can follow the textbox in the right column, which will lead you to the corresponding page in the new Forum. Alternatively, you can start from the main page by following this link:
https://sieportal.siemens.com/en-ww/support/forum
In the coming days, we will update the configuration step by step, so that you are directed to the new Forum by default. The “classic Forum” will remain available for all known functionalities alongside the new one.
We are thrilled to finally share the future of our Forum with you. Thank you for your commitment!
Kind regards,
the Forum Support Team
