2/21/2014 8:37 AM | |
Posts: 1299 Rating:
Hello, click on the button in the menü. click on events, change the function list to vb script (with the 5th symbol) and add your script just like normally. see also this chapter in manual K!ke |
2/25/2014 8:18 AM | |
Posts: 1299 Rating:
Hello, https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=56521909643&TopicId=52009686283 1) property is called "Visible" 3) property is called "ScreenName" 4) property is called "MenuToolBarConfig" you can also do this without script by using thefunction list. K!ke |
12/5/2016 3:54 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by saddy hussain is split to a separate thread with the subject Toolbar, how can i set this Menu tab to be displayed in the required screens?. Best regards |
