7/14/2020 4:17 PM | |
Joined: 8/10/2017 Last visit: 6/6/2024 Posts: 22 Rating:
Hi, I need to migrate an HMi project integrated in STEP v5.6+ SP2, WinCC Flexible 2008 SP5 into TIA and MP377 19'' into TIA V15.1. I tried following the procedure MP 277 Touch Entry ID 54695062 and tried with TIA V13, V14 and V15.1 all return the same error during migration : Do i need to change my HMI device in WinCC flex ? if so could you advise which one if compatible ? If not, any other idea ? Many thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/20/2020 09:09:57New subject after splitting |
7/20/2020 5:24 AM | |
Joined: 9/21/2012 Last visit: 4/27/2025 Posts: 4404 Rating:
What does the error lines say? There you will find your answer... |
