4/16/2013 3:23 PM | |
Posts: 3037 Rating: (192)
Hello TWF, You can not migrate a project from WinCC TIA Portal to WinCC flexible. TIA Portal Tweety |
4/26/2013 10:27 AM | |
Posts: 3 Rating: (0) |
And if i load the program on the panel with TIA, (it will be a TP1500 Basic), is it possible to recover it from the panel with WinccFlex ? thanks. |
4/26/2013 1:10 PM | |
Hello, You can not work with Wincc flexible with an TP1500 Basic project which you create with WinCC TIA Portal. Tweety |
