8/9/2022 7:57 PM | |
Posts: 71 Rating:
Hello Will7991, I suggest you to read the following application example which may help you solving issues during migration from older versions of WinCC to TIA Portal. Migration of a WinCC flexible project integrated in STEP 7 V5.x to WinCC (TIA Portal) and upgrading of the operator panel version after a change of the WinCC (TIA Portal) version to a newer version. https://support.industry.siemens.com/cs/ww/en/view/77430539 Best regards, s7-mencey. PD: If this post helped you, don't forget to rate with 5 stars! |
