2/3/2021 3:31 PM | |
Joined: 10/11/2011 Last visit: 3/13/2025 Posts: 2 Rating:
I have the same problem now, have you folved this problem? |
2/4/2021 9:22 AM | |
Joined: 5/12/2006 Last visit: 4/24/2025 Posts: 22624 Rating:
which one exactly? in the topic 2 problems reported |
2/5/2021 10:09 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello check this FAQ: https://support.industry.siemens.com/cs/de/en/view/109486003 And of course also this faq: https://support.industry.siemens.com/cs/ww/en/view/54695062 If you do not have wincc Flexible and TIA on the same System then you can use the TIA Migration Tool. Bye Murof |
