6/15/2015 9:45 PM | |
Joined: 9/27/2006 Last visit: 3/27/2023 Posts: 11997 Rating:
Hello Vlad; Have a look at this document, it should give you some basic information for your migration:
SIMATIC HMI HMI Device TP 177A, TP 177B, OP 177B (WinCC flexible) Communication settings are defined in the WinCC Flexible application, and integrating the HMI project in step 7, al;though not a requirement, will make your life much easier (and project development much shorter), as all tag symbols and project information will be available to the HMI program without having to copy everything. You can seacrch for FAQs and manuals on WinCC Flexible using the search box at the right of this page. Hope this helps, Daniel Chartier |
6/15/2015 10:20 PM | |
Posts: 10 Rating:
Thanks Daniel. I
was confused because project with TP177a could be also |
6/16/2015 12:04 PM | |
Posts: 10 Rating:
Hello Daniel. But is this possible to to link PLC project created in STEP7 v5.5 with HMI project created in WINCC TIA Portal? |
6/16/2015 1:30 PM | |
Hello Vlad; The following document presents different solutions for linking a program developed in Step 7 v. 5.5 to an HMI programmed with TIA Portal: Joint Configuration with WinCC (TIA Portal) and STEP 7 Hope this helps, Daniel Chartier |
6/16/2015 2:01 PM | |
Posts: 10 Rating:
Many thanks for help Daniel. |
