6/13/2008 4:58 PM | |
Posts: 510 Rating:
Look at the file \\Program Files\Siemens\Wincc\Diagnose\WinCC_SStart_0x.log where x is a number. This should give you an indication on where the system is hanging. My experience isAlarm Logging or Tag Loggingare normally the culprits. Otherwise, in the Startup tab of the computer properties, you can uncheck everything but GraphicRuntime and attempt to start up. If successful, then keep adding runtimes until you find the one that is failing. Then we can determine how to proceed. |
6/13/2008 6:46 PM | |
Posts: 2661 Rating:
G2481: Did you try to activate the RT after deleting the "old" archive? |
6/15/2008 2:02 PM | |
Posts: 42 Rating:
Please install SP2 while this solves a lot of the strtup issues with WinCC 6.2. Markus |
6/27/2008 8:30 AM | |
Posts: 31 Rating:
Thanks, problem solved. we need to install WinCC v6.2 SP2. |
