9/26/2008 7:21 AM | |
Posts: 1064 Rating: (72) |
check out the ik pi book section 7 |
9/26/2008 8:04 AM | |
Joined: 9/27/2006 Last visit: 1/17/2025 Posts: 12330 Rating: (2700) |
Hello john; Here is a suggestion. The following site will take you to the As-interface.net Products page, where I did a search on Manufacturer (Siemens) and Cable; here is one of the hits I got: http://www.as-interface.net/Products/F9629746-F855-4728-AF3F-A6731B77FFEB Now, you can keep looking at the different hits on the as-interface page, of follow the link to Siemens AS-i product line. There are also many other vendors offering similar products you can look at on the AS-i webpage. Hoep this helps, Daniel Chartier |
9/26/2008 1:17 PM | |
Hello john; The link I provided would have brought you to this page eventually, with a little patience and persistance: https://mall.automation.siemens.com/WW/guest/index.asp?lang=en&aktprim=-1&aktTab=1&nodeID=8200056&searchScope=subtree&subtreeID=8200056&searchIn=ARTICLE_NUMBER&searchtext=* Do searches for your other products in the Mall interface, you should find what you need. Hope this helps, Daniel Chartier Edit; Sorry john; the link provided was not correct for some reason, although I had copied it from a Siem,ens Catalog link.. It takes you to one of the search pages of the Mall, but the settings for the search are not filled-in properly. Look at the following attachment, use it as a template to search for M-12 As-i modules (notice you must check the ProductDescription selection for this to work); this should give you all your requirements. Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 9/26/2008 2:04 PMOriginal link to Mall not complete Last edited by: dchartier at: 9/26/2008 1:20 PM |
9/26/2008 3:45 PM | |
Posts: 487 Rating: (45) |
Check the link below from A&D Mall, there are lot of ASi M12 accessories here too. https://mall.automation.siemens.com/DE/guest/index.asp?aktprim=0&nodeID=10020562&lang=en |
